'78 Ebko Lebaron - Therapy
  • Total voters
    13
  • Poll closed .
Trooper82
Re: '78 Ebko Lebaron - Therapy
You know it Gus...btw...your supplier does gel coat too!
Pmccraney
Troop, the portion that your polished looks really good.... I know this boat is important to you and I appreciate your dedication and attention to detail. You definitely hold yourself to a high standard.
I am by no means advocating cutting corners -- especially given the sentimental value of this boat and the time you have put into it thus far. However, just don't beat yourself trying to get things absolutely perfect on the gel (its hard enough in a factory setting, much less your garage). You are doing a great job and I can tell the end product is going to reflect your hard work.
Hang in there.
Trooper82
You are right PMC.....but I just can't help it...
So tonight I get home...stick some 80 grit on the sander and scuff the transom up....drill a hole in my hvlp tip..use the mini drill press and some lapping compound to seat the jet....wipe down the transom....get the air tank filled...mix up a batch of gel and start spraying again...
Only problem was the tip getting a little clogged still and spitting out little nibs...
Ate some suppper...went out and took the heat gun to it...got it to harden up and started sanding with a small hand block to get the nibs down level...was only using 320 and worked real good...tok my last sheet of 320 and started sanding..water and soap....is coming out real good...I'm happy with the progress so far...more tomorrow...
Lakeshadow
Great job Troop. Your work looks to exceed factory tolerances. From the water line up she'll be a sweet visual in the drink!
Trooper82
Markered up...
I thought I was close...using 320 grit
but not even close!
Some 220 wet...
and 220 dry...
GT1000000
That looks AMAZING!
Did you finally get full coverage after achieving that result?
Trooper82
Picked up one of those variable speed polishers on sale @ hf...man that things bring out the shine...but sadly I had sanded too deep again....
so tonight I sprayed 1 liter of gel from my pressure pot...just on the back of the boat...no way to check the thickness but hoping it was enough...I,put wax in the mix so it will cure...can I spray a second coat tomorrow without sanding or will I need to sand the top layer off first? I am thinking I will need to sand it first....
jbcurt00
Any chance there won't be any sanding next weekend? Because this Sun there will be. :facepalm:
Pmccraney
Looks great so far! good luck... I think you should write a book: "Zen and the art of Sanding." (secretly, I think you like it) :).
Trooper82
By now it should be no secret :)
I swear the boat is a good foot shorter by now...
saginawbayboater
Troop you sir are persistent! I believe gel to be a great and noble task!:hail:
Trooper82
This is after all the sanding today...
and this is after all the buffing...shees I need to clean up the garage!
You can see my dirty shoes...
Still not perfect but it is going to have to be good enough...
GT1000000
OOOOh-LA-LA!!!:eyebrows:
Suh-WEEEEEET!:thumb:
Very shiny, me likey!:cool-new:
