trim motor does not lower or raise engine
riverroad
Had unfortunate luck when the trim stop punctured top of trim motor on Nissian 90A. I have ordered and installed a new trim motor, trim stop and refilled the trim reservoir. The trim motor is getting power from the switch. Out of troubleshooting ideas.
TOHATSU GURU
Re: trim motor does not lower or raise engine
You need to either go through the troubleshoot guide in the manual or run it by any kind dealer.
sea_stork
Have you tried jumping the main lugs on the trim solenoids to see if it might be them?
