Re: '77 Luhrs 28 ft. diesel repower - just beginning
Yes the weather has been nice and warm still, so I'm trying to keep forging ahead with anything involving adhesives or coatings.
Yesterday I finally got my thru-hulls/seacocks permanently installed with 5200. I used backing plates of 1/2" thick fiberglass instead of wood. I think that 1/2" fiberglass plate would stop a round from a .44 Magnum. It took quite awhile to get through them with a hole saw.
I'm also going to fair in all around the outer pickup with epoxy.
I sanded, stained and put 3 coats of clear spar urethane on the "dashboard" inside the cabin:
Gettin' ready to install the waste tank for the head:
When I bought the boat it had an electrical treatment unit and no connection to pump it out. It only had a hose going to a thru-hull in the bottom with a valve. Maybe that was legal in 1977 but it sure isn't now so I'm setting it up so the only way the tank can be emptied is to pump it out. That should make the Coast Guard happy if they stop me for an inspection.
I'm going to head over to the boatyard and see what I can do today. One thing I've been putting off is messing with the twin 65-gal fuel tanks. I was trying to just leave them in place but I might have to yank them to add a return line fitting. (the diesel injection system has to be able to return fuel to the tank)
