71 100hp no top end power
tacodads
Hi,
Boat was running good now I don't have the topend like it did. the only thing I did was take the air intake off and look at the butterflies, then put back, now no power
Thanks for any help,
Taco
kenmyfam
Re: 71 100hp no top end power
Are you sure that is all you did ??
Explain "no power" a little more for us all. RPM, performance, won't idle etc. What you did should not have altered anything unless you altered something within.
tacodads
Boat starts, gets going, but only 5-10mph. Originally had it to 35. I did adjust the height of the choke solenoid. so it would close completely on start-up.
Thanks
tashasdaddy
you motor has a heat sensor choke,(like a choke on a car), there was a service bulletin to disconnect one of the purple wires on the buss bar, to disable that function. it caused the motor to flood out. also make sure the choke butterfly is going all the way back to horizonal.
tacodads
Thanks! will try it today.
tacodads
Linkage to 1 carb was disconected. fired right up then overheated. what next?
tacodads
was the therostat. Took it out and it ran great. put the new one in tonight, will have to wait to take it out again.
