69 starcraft for newbie?
Woodonglass
Re: 69 starcraft for newbie?
In your photobucket album, hover the mouse over the picture you want and a popup window will appear. The bottom tag is the IMG tag. Click that IMG Code window and it will say copied. Now return to iBoats and go to your post. Hold down the CTRL Key and keep it held down and press the "V" key. Your picture will be pasted into your post. That easy.
Donkalion
Donkalion
Now that I figured out how to send picture from the iPad we can get this show rolling. Well I have gutted the entire deck and performed the leak test today I had a few leak but I'm really clueless about we're to start for repair. More pics on the way!
Donkalion
Photos of the leaks two were small holes and one a rivet. I understand about the rivet but what about the holes and also were can I order those style rivets?
kfa4303
Banned
HI Donk. Jas is right. Rebuck the bad, old rivets. This really just entails having a partner hold a hammer on one side of the rivet while you hit it from the other side to tighten it back up (i.e. rebuck it). You can also drill out any old/bad rivets and replace them all together. Blind end pop rivets work well and are readily available. Gluv-it is a liquid epoxy with the consistency of honey that you paint along the interior, riveted seams found below the waterline of the boat after they've been thoroughly cleaned. It will get in to every nook and cranny of the seams yet dry flexible an strong. It does need some UV protection so you'll either need to paint it, or put a floor over the top, which is what I think you're doing. Be sure you never use pressure treated lumber and do use stainless steel hardware throughout (excluding any aluminum replacement rivets, of course). Here's avid that can show you how to do the rivets. Any small, non-rivet holes can usually be patched up by a welder for a few bucks, or you can use products like JB weld stick, marine epoxy for hole smaller than say a quarter or dime.
http://www.youtube.com/watch?v=L0MA1-5NXjs
Donkalion
Thanks I have the Gluvit on order and I will pick up some SS rivets tomorrow.
