68 starcraft explorer restore
umtnman
Re: 68 starcraft explorer restore
Yea i'm going to add more support. I think i'm going to flip it and paint it. then when I reflip it I will add the extra support. My son
finished getting the pinstripes off today by himself when he got home from school. I work afternoon shift so I don't have alot of time
to work with him. Tonight I made some small sawhorses for when I flip the boat. They will screw to the craddle and keep the boat at a
good level to sand and paint, I hope. Putting my order in thursday for all my glassing supplies(i hope all).
What size fiber strands should I use to bead in the stringers?
Woodonglass
Honorary Supreme Mariner
The sheet foam, if installed properly will offer great support for your deck as well. With the added benefit of NEVER absorbing water. NEVER. Can't say that about the Pourable stuff. Easy to cut and shape so you will have a minimal of voids, especially on your boats layout.
Your boat...Your choices.;)
jigngrub
I'd never put sheet foam in a fiberglass boat, and I consider it only mediocre for aluminum boats.
Expanding foam will never absoeb water if you take care of your boat and keep it covered to protect all of the hard work you've done to it after your restoration.
From the foam FAQ section at the USComposites sites:
14. Is this foam water resistant?
Yes, but with the following caveat. The foams that we sell are considered closed-cell, which means that each cell that makes up the foam structure is completely closed off from surrounding cells which prevents it from acting like a sponge. It is completely safe for this foam to be in contact with water for hours/days/weeks and even months with no adverse effects. However, it should never be submerged in contact with water permanently. Over a period of years the water contact can begin to soften the foam and cause it to lose its closed-cell status. This foam is designed primarily to be used as an insurance policy in case of damage/holes that could cause a vessel to lose buoyancy. Pinhole sized openings would essentially have no effect on the foam since the amount of exposure is so minimal but you should always make repairs as soon as possible to keep the foam effectiveness as good as possible. This will be the case with all after market closed-cell polyurethane foams and even manufacturer installed foams.
A lot of people don't understan this about expanding urethane foam.
kcress0217
Looks like we are working on similar projects, I'm working on a 65 Explorer. I see you cut a hole in the front platform, is there anything interesting underneath? I assume it is just hollow space, but I don't know as that is the only area that I haven't really touched on mine. Also, did you add the cap to your boat or did it come with it? I know mine does not have a cap and in the one or two pictures I've seen from the 65 Starcraft ads they don't seem to have one. I haven't seen any old pictures of the 68s though.
umtnman
Nothing spacial under front platform. It was soft so it was very easy it remove. I think it must have been a compartment at some time.
The cap is original. I should be flipping it this weekend so I can start preping it for paint. Have you started a thread yet? I plan on
extending the platform back 3-4 foot and raising it 4-6 inches.
umtnman
Goggle starcraft clasic boat library. It has some old pics and information. Mine looks like the 1967 explorer Tr page 26.
umtnman
Is the bondo jelly OK to fill old snap holes above waterline. I'm ready to flip the boat but must wait till sun when I can get some help. Thought I would start filling holes and start the prep work on the sides of the Hull. Which primer from tsc should I use?
jigngrub
Bondo isn't usually acceptable for marine applications, a polyester based filler like peanut butter or an epoxy type filler are better suited for boats.
How many holes do you have to fill, a gazillion?
umtnman
Prob 25. Holes 3-4 in down from top of sides. Well above water line.
umtnman
Thanks that sounds just like the jelly but thinner.
umtnman
I was able to get the holes filled. Then a buddy of mine and I thought we could flip it over. Well its over with no major problems. Now comes the sanding part. I. Wont get a lot done Sunday because I'm taking my son to the. Boat sport and travel show.
umtnman
Welll sanding is going about as good as to be expected. I should have around 3 more nights left. I have given up the idea of using this boat the end of March. I would have to start rushing thing and I am putting to much work and money in it not to do the best I can on it.
Woodonglass
I remember this part!!! Just remember only YOU will no where the imperfections are. Fish won't care. I spend a LOT of time making Mine perfect and smooth as a baby's behind. First day out the trailer loading went bad and the imperfections were ALL back Plus some. My advice, make sure the major stuff is taken care of and finish it. When you're on the water you'll forget all about those little imperfections.
umtnman
Thanks for the advice. Yea read your post about your restore. That would have made me sick.
umtnman
All the old paint is gone. My supplies will b n wed then I can repair a few spots and get to painting. We made plans to go to blood river on ky lake for the kids spring break. Cant wait a full week of camping and fishing with my two kids. 13 and 14. Girl and boy. I will b taking my backup 14 footer w a 7 hp. Anyone been down in that area.
