'67 Holiday 18' - Make it Usable
SHSU
Lieutenant Junior+Starmada Splash Of The Year 2019
Nothing like a good wire job to "energize" the boat. lol
SHSU
Berdink
I'm only going to go in freshwater in this boat.
What size and how many magnesium anodes should I mount to my hull? I figured I'd put them under the water line on bare aluminum skin of the transum.
SHSU
I only have one zinc on my motor and replace every couple years. I would only put one on and keep an eye. Unless you got a major issue or leave it in water near other boats that get shore power you shouldn't have an issue. Trailer queens like ours don't have the same risk.
SHSU
Berdink
I removed the rat's nest. I'm going to go with rechargeable LEDs so I don't have to run any wiring for the few occasions I need running lights.
SHSU
Rechargeable running lights, I never thought of that but makes sense since I seen them on kayaks and stuff. Smart move to limit wiring.
SHSU
Berdink
I'm still tinkering with the electrical.
I've been keeping a lookout for a windshield with a swing door center section. My windshield made it difficult to get out to the bow. I picked this up today. This is it on another boat. By measuring things out, it looks like it's going to be a great replacement for mine.
Berdink
Does anyone have a measurement for how high the stock windshield is perpendicular to the dash?
I'm looking like I'm going to be at 24 inches straight up from the dash at the middle.
Berdink
I haven't gotten around to trying the color anywhere on the boat, but here's a couple more examples of how well it matches in different lightings.
It picks up the different hues.
I thought I had pics in here where I sanded, scrapped, and cleaned up the bottom and then primer. I hit a light spray coat with etching for the bare spots and then Sherwin Williams oil based primer.
Today I painted the bottom with the Sherwin Williams color match mix, and I'm real happy with the match.
Berdink
I just wanted to get the corrosion on the bottom cleaned up, treated, and painted sooner than later.
I hope to paint the sides this summer.
Berdink
I must have not sealed the holes that I made for the sacrificial nodes because I took in probably two or three gallons of water being out front 7am to 430pm.
I'm going dumb about 5 gallons of water inside and see if I can see where the leak is.
Berdink
I've been really happy with my beater.
It's not pretty, but it does the job and doesn't leak one bit.
I plan on keeping it ugly but safe, solid, and reliable.
The keel and bunk rollers had worn out so instead of replacing them I researched and learned that bunks would give my riveted boat better support.
I am jacking them up bare wood tight to the hull so I can get them adjusted perfectly flat. Then I will carpet them.
SHSU
Don't carpet if you are going to use in saltwater. If not, then shouldn't be a problem.
SHSU
Berdink
Once a year for three days in brackish water.
Would Salt-Away remove the salt from the carpet?
SHSU
There are varying opinions on Salt-Away, I personally haven't tried it so I can't say. That being said, 8 out of 10 trips will be in saltwater for us and I only use water/soap.
I would guess that it should be fine, if not primarily used for that and you rinse it off as best you can when you do.
SHSU
