Re: 3.9hp no bowel movement
duckhunterjon,
thanks for chiming in. yeah, im trying to get this little motor fixed because im gonna use this for my inflatable tender so i can head to the beach off from my bayliner capri. i like it cuz it really light and compact.
hey bktheking, yes, i checked the grommets and it seems to keep the seal fine. thanks for reminding me, i wanted to ask where abouts did you pick these up? its getting harder and harder to find parts for this motor and ive been 'mcgyvering' a couple things on the way.
well heres the scoop. the gasket sealant solved the bubbles from below. the gasses were escaping below.
i fired her up and all seems well but no stream out of the tell tale.
opened up the cowl and i saw where water was escaping out the area where the powerhead meets the midsection. good sign.
so i unscrewed the screw where it says water flush
and then fired her up.
at least its starting to pee up there. im thinking the powerhead and the midsection are not sealed properly. i had to manually trace out a new gasket for that and i didnt put enough gasket sealant creating water to escape there. i layed more gasket sealant around the area and hopefully that will do the trick. i will wait another day to fire her up and hoping this will solve everything.
curious anyone know off the top of there head what the torque measurements are for the bolts connecting the powerhead to the midsection? i was looking in the manual and not having luck on the torque specifcations. i just tighted hard enough where i think it would be tight. thanks everyone, i can see the light at the end of the tunnel, choo choo like my 2 year old son would say!
