3.7l breezeworks alt wires
scameron7
just installed electronic ignition and alt. conversion on 1988 3.7l where does the black wire on the alt. go to 3 wire alt and what do i do with the wires that ran to the voltage regulator,
thanks scott
Don S
Re: 3.7l breezeworks alt wires
The black wire is just a ground. Any place on the block should be fine.
Assuming you are referring to the yellow/red wires coming from the stator. Personally, I would recommend you remove the stator. That way when (not if) a magnet come loose, it doesn't destroy the pulley when it catches on the stator.
The red/purple and the orange wire will go to the alternator.
scameron7
i removed the stator just installed sleeves on my cam shaft, where does the red/purple and orange wires hook up at?
scameron7
Thanks for the wiring diagram don s. it's what I needed.
