3.0 to 5.7 swap
Ripcurl7278
I bought a 19 foot bowriver with a 3.0 knowing id have to replace the motor because it was shot. i have a few months to work on it until its warm and want to do a swap to a 5.7 DROP IN. not worried aout the time and money im fine with that. i just want to know if anyone has the motor mount spacing or placement or a layout for the front motor mounts so i know how to check if i can cut and fiberglass to make this work. thi would be a great help. thanks, steve.
matt167
Re: 3.0 to 5.7 swap
your best bet is to wait and do the modification when you get a motor. You will need a new transom plate and leg among other things ( entire new engine/ drive ), so a rotted donor boat could give you the dimensions and drive system you need
Bob_VT
Re: 3.0 to 5.7 swap
Ripcurl7278 your other post was deleted. You only need to post your question one time and not multiple times in other sections.
Thank you.
Yes, you will need to have a complete donor set up .....it is not a drop in at all and you might have to do some structural work to support the new motor. Absolutely not an easy "drop in" job.
thumpar
Re: 3.0 to 5.7 swap
You are better off just buying a boat with the engine you want to start with.
tazrig
Re: 3.0 to 5.7 swap
How heavy is the boat? a 5.7L in a light (2,000 lbs.) boat is a lot of ponies... are you sure you can almost double the engine safely??
Howard Sterndrive
Re: 3.0 to 5.7 swap
I went from a 3.0 to a chev V6 in my boat and I didn't have to do anything to the transom assembly. All chevy engines in boats have the same rear bolt pattern so the 3.0 flywheel cover will swap onto a V8.
I just removed the 3l exhaust pipe and fitted a Y pipe.
The drive itself will have to change for gear ratio - at least the upper half. the lowers are all the same as long as all same generation
Maclin
Re: 3.0 to 5.7 swap
If not worried about the money then it shouldn't matter what boat you spend it on, like another one with a V8 that already runs :confused:
