3.0 omc missing
Frankpic
I have a 1987 omc 3.0 that developed a misfire while under load I already changed plugs, wires, cap,rotor ,and coil also fuel line it’s been changed over to electronic ignition already before I purchased it
The volt gauge bounces around
I’m at a loss any help would be greatly appreciated
welcome aboard
your voltage gauge should be rock solid steady and not move
check all your connections
it wouldnt be the coil, so you just spent $50 for nothing
check the plug colors and report back.
kenny nunez
Also check the backside of the instrument panel and ignition switch, put you fingers on every terminal to see if there is a loose connection.
matt167
missfire would have me checking compression and valve adjustment. It's just a Chevy and should have hydraulic lifters so you can adjust them running most likely
