2018 Triton TRX 20 Trailer Wiring Harness
rgraham8648
I need to replace the wiring harness on my 2018 year Triton model TRX20 trailer. Any recommendations where i can purchase one? TIA
You will need to buy trailer wiring and rewire it yourself. They don't sell "trailer harnesses" pre-made
HRG
You can buy a LED tail light kit that comes with long wires that have a connector to plug into your tow vehicle's trailer connector.
I recently bought this Maxxhaul 70205 LED trailer tail light kit from Amazon for $26.99. Replaced the incadescent tail lights that came with my new EZloader trailer, with the LED ones. Works perfectly. This kit uses the 4 flat connector. There are other kits that use different connectors to match your tow vehicle's connector.
matt167
You can get Hopkins wiring products almost anywhere. Even Walmart
airshot
Many of these kits are availiable with different length's of wire, for example...a 20' boat trailer or a 24' boat trailer etc. Read carefully to get a kit with long enough wires, then trim to fit your application. If you dont already have LED lights, give them serious consideration, you wont be sorry!!!
