2008 150 efi no fuel to engine
RJSmith
I cant get the fuel to the bulb , took bulb out and replaced it still no gas i think i have presure problem put pressure in the fuel tank and fuel came to the bulb . seems like there is either not enough pressure to let the fuel to the bulb or to much dont know. brand new boat been in water 2 times
Alvarez
Re: 2008 150 efi no fuel to engine
Disconnect primer bulb from the end that goes to the engine.Raise the primer bulb high enough and pump it to bleed system.Make sure you don;t get fuel to spill on you point primer high and away from you.Once is pumping connect it back on.If no fuel is coming out take water seperator out and inspect it.Work your way to the top of the tank there is an access cover there.Maybe the supply hose is loose from tank to water seperator..
blazer81.6
Check all fuel line connections. Sounds like your loosing pressure due to a fuel/air leak.
