2002 mercury 40 hp 2 stroke
Beamer50
0T518996 timing way off 25 at idle , new trigger, new stator and flywheel had been replaced last year before I purchased it , looks new , just spent $350 @ mercury marine dealer for link & sync single carburetor
I checked timing after bad day on lake cutting off , no top speed , I need help im frustrated and baffled Thanks Beamer50
Dave1027
Are you saying the timing at idle is 25 BTDC ? Sounds like you got scammed by the dealer. I'd start by demanding your money back. Then fix it yourself with help from forum.
Beamer50
You're right Dave and thanks. To the right of the flywheel timing marks is a white dot at 8 degrees. It's supposed to be set between 7 & 9 degrees BTDC It only goes to 20 I think to the right. To the left 0 TDC it goes to 40 I believe but my timing light showers it to the left of the TDC mark at 25?
Beamer50
is 8 degrees before TDC to the right of 0 TDC ? if so it's marked right. But timing light showing 25 to the left of flywheel markings 0 TDC ?
Dave1027
Since the flywheel spins clockwise, BeforeTDC is on the left and AfterTDC is on the right. I would think 25 BTDC would be the max timing setting with the idle timing setting in the 0 TDC range and possibly even ATDC a few degrees but I don't have your motors specs in front of me.
flyingscott
I can pretty much guarantee you are not idling at 25 degrees. Look to make sure the carbs are opening all the way. Do a spark test and compression test. if they put CDI parts on, a thorough test of those are in order.
Beamer50
Flyingscott, I had to take a couple of day break from it. But I was going out in a few to check it out. I put two new CDI on it before shop. And the carburetor is open 100 % at full throttle, now. I don't think I can adjust the link enough to get it to 7 to 9 BTDC. I'm going to take the top plug out and verify TDC. The flywheel was put on before I bought it and it looks like it may have come off while running with some pretty good scraps in the metal between the flywheel and oil tank bracket which I didn't notice at the time. Just checked compression. The flywheel looks brand new but I guess it's possible it spun in the center since I verified it's the correct one.
I will keep ya'll posted today after these checks. I really appreciate any and all the help. Beamer50
Dave1027
If you find the pointer is off then you should pull the flywheel to check the condition of the flywheel key. If the key is damaged and the flywheel spun, that is even more reason to demand your money back from the scammers at the dealer.
Beamer50
Thanks, Dave, and they are scammers, I just pulled # 1 top cyc. this is a 2 cylinder. and it is on 0 TDC with piston up. So that rules that out. The timing is showing 20 degrees BTDC. I cannot adjust the trigger link enough to even get close to 7 to 9 BTDC which is what the Seloc manual calls for???
Dave1027
Did the timing arm come loose from the trigger? Post a picture of the side of the motor with the timing arm.
Beamer50
Pictures
Beamer50
Pictures of 2002 m
Beamer50
Dave, take a look at the bottom end of the trigger link, it's very close, touching the rubber stop???
Dave1027
Looks like something is missing from your linkages. I think it's missing a part that connects the throttle to the timing.
Post a picture with it in the full throttle position.
Beamer50
Man, I'm scared to take it to a dealer now. They already robbed me. I told um a good mercury mechanic should be able to sync one carb & time it in 45 mins. But you charged me 2 hrs. labor. Well, it takes longer than you think. I said I'm glad it doesn't have 3 or 4 carbs. I know this is a good buddy help forum but there's a nice Amazon Card for you. I guess it's ok to gift??
