2000 90hp Johnson Hard to start.
Roberthill
Primer clicks when key is pushed in but won't start until red primer indicator is turned up . What should I do to fix this??
Honorary Supreme Mariner
Key is to be pushed in and held in while cranking the motor over.
Roberthill
Did that but still won't start it turns over but won't start running until I lift up the primer indicator.
Take primer apart as plunger may be " sticky " in the bore.
