Hi Can somebody tell me how much gear lube I need for my gearcase? Thanks Rod
Rodster44 Seaman Joined Jun 3, 2007 Messages 53 Oct 7, 2008 #1 Hi Can somebody tell me how much gear lube I need for my gearcase? Thanks Rod
C Chris1956 Supreme Mariner Joined Mar 25, 2004 Messages 28,890 Oct 7, 2008 #2 Re: 1999 Johnson 150 gear lube 25-28 oz. You will need to buy two qts of gear lube if you use a pump to fill the gearcase, since they do not pump the bottle dry.
NelsonQ Lieutenant Joined Aug 5, 2008 Messages 1,413 Oct 7, 2008 #3 Re: 1999 Johnson 150 gear lube Chris1956 said: 25-28 oz. You will need to buy two qts of gear lube if you use a pump to fill the gearcase, since they do not pump the bottle dry. Click to expand... I use a hand pump to allow me to get empty the entire liter (quart) and find it a little easier to fill the lower unit with it. Real cheap and convenient http://www.iboats.com/Fluid_Pump_Lu...23406890--**********.426412915--view_id.56375
Rodster44 Seaman Joined Jun 3, 2007 Messages 53 Oct 7, 2008 #4 Re: 1999 Johnson 150 gear lube Thanks for the info Rod
