oldboat1
- Apr 3, 2002
- 9,612
As discussed above, you need 3/8 inch spark. This is measured with an open air tester -- need to get one of these cheap devices at an auto parts store, if you don't have one in your tool box.
How did you test for spark?
Once you know for sure you have solid spark from a strong ignition, you can bypass the carb and spray some mix directly into the cylinders and see if it will pop.
