1996 OMC Cobra / Volvo SX gaskets
Lpgc
I worry about even using 25ftlbs torque on the nuts to pull the drive on because the clamping force is a lot higher than the 25lbs... so if something isn't right it could damage it?
Lou C
I bet the guys in shop get it "close" and then wham it on with an impact gun (cringe)!
There used to be a very knowledgeable Merc tech on here (AChris?) who posted vids of how he got Merc Alphas on, he used a strategy called the Mercruiser Kick.... yes, he put on a boot and kicked the end of the upper gear housing to get it to go IIRC lol...I think he jokingly said he used a Mercruiser approved boot, does anyone else remember that?
We OMC/Volvo guys are a bit more genteel, we sweet talk our drives to sliding on, violence usually doesn't work too well lol.
Lpgc
I'll try tghtening the middle nuts without using much torque/force, see if I can judge if it's pulling on OK or something is stopping it. Then do as I said and put the drive in gear, disable engine ignition and crank the engine to see if the prop turns... Unless you/anyone thinks that's a bad idea?
Lpgc
Would it be possible to have the splined shaft through the gimble bearing... but either the end of it miss the coupler splines (so dig into the rubber on the coupler) or for there still to be some kind of problem with Ujoint alignment, while the drive still seems to pull on OK? I just don't want to mess anything up by pulling the drive on that final bit or especially when I crank the engine. If the end of the splied shaft were digging into the coupler rubber or if the Ujoints were not in correct alignment it could cause a lot of damage if I crank the engine.
Lou C
I'd at least tighten all 6 to 25 ft lbs, and honestly I have some years not even used a torque wrench, just get it good and tight, and never has a problem doing it that way. Even 50 ft lbs isn't that much.
Lou C
If the splined shaft didn't go in the coupler the drive won't even be close to going on, either it's going in, or not but if not, you won't even be able to get the mount holes on the drive onto the studs. I forget how many inches of the driveshaft is actually in the coupler splines but it's probably about 2", maybe a bit more.
Horigan
I made a dolly cart from a $14 Harbor Freight cart, adding 2x6s to build a structure the drive will sit on. You need to be able to get your hands into the bellows and on the U-joint to hold it up and centered, even with the splines started, while you wiggle the U-joint while pushing the drive/cart in.
Dolly Cart
Lou C
Post up a pic of the way you are supporting the drive, from the side, let's see what is happening there.
I have also heard of people modifying motorcycle jacks to lift outdrives.
Anything it better than trying to man-handle it on, that's a sure recipe for frustration and back pain.
Lou C
Dolly Cart
Yep but be careful with your hands in there because it can all of a sudden slight right in, on your finger lol. I use the long thin screwdriver to hold up the double cardan assembly.
Lpgc
Sorry it's been a while since I posted, I had to break off from the boat when a customer arrived
But I got the drive back on just before the customer arived! It took hardly any torque on the middle nuts to pull it on. I know this customer well, so after I'd sorted his car (Jeep SRT8) I put the drive in gear and asked him to watch the prop shaft while I cranked the engine, it's turning OK so I doubt there can be much wrong with it.
It's dark here now but I'll take a pic of how I supported the drive tomorrow. I haven't finished torquing the nuts fully, then I'll need to reconnect the shift link, put some gear oil in it (I drained the drive before removal), attach the rams and fit the prop.
Maybe take the boat to the river one time before I winterise it just to make sure it's good to go for next season.
Thanks for your help :)
Lou C
Glad to be of help to you, all of us backyard/driveway marine "mechanics" have been there done that, and learned a few tricks along the way. If it went on, as you describe, it's probably just fine. This job is all in the setup:
level ground where you are working,
gimble bearing centered with the alignment tool first,
transom mount (OMC and Volvo called it the pivot housing) & outdrive at the same height,
mating edges of the pivot housing and outdrive are parallel to each other,
wheeled jack or platform to slide it on,
long thin screwdriver to work the Ujoints if needed, etc.
Now you know why some saltwater mechanics call I/Os "Double Trouble" lol.
Lpgc
Thanks Lou.
I've removed an refitted the drive several times before but never had this much trouble before, it's also the first time I've changed a gimble bearing.
For sure it seemed like double trouble when I had to extend the height of my engine crane and remove interior trim from the boat before I could lift the engine out and when I rebuilt the engine lol.
I think I was a bit stronger a couple of years ago, used to be into bodybuilding into my 30's and still had some of that strength so it was less of a problem to lift the drive and shake it around than it is now. In the last couple of years I've had 2 frozen shoulders.
So far today I've filled the drive with fresh 75/90 GL5 fluid, the old stuff that came out before I removed the drive still looked clean with no water in it. Just about to re-attach the rams and might get around to putting the prop back on... But might leave the prop for another day because I want to go out shooting with my young son.
This is how I ended up supporting the drive to help get it on. I previously tried just manhandling it and using a trolley jack without even jacking the boat trailer up. I now have the trailer jacked.
Lpgc
The threads are damaged on one end of the main pivot pin but I managed to get the nut on tight last year. New pins are expensive so I might cross drill the ends of the pivot pin and put a split pin through the drilled holes to make sure the nut can't come off. I bought 8 new of the hard plastic shims that go in the ends of the rams and drive pin hole but it seems I only have 7 of the soft rubber seals that go on the hard plastic shims. I'll order another rubber but I think it'll be OK to leave one of the rubbers out just for testing the boat one time on the river before winterising it..? Do we coat the pin with grease?
Lou C
You can probably find the pivot pin on ebay, here in the USA there is a company on ebay by the name of NLA Marine that sells a lot of freshwater used outdrive parts.
Yes for sure grease the pin, with marine grease.
Just another tip, I coat the threads of all bolts/fittings for the outdrive, with Evinrude gasket sealer, or Permatex Aviation sealer, it seals the threads from water getting in and causing corrosion and that makes taking things apart, much easier.
Looking at your boat I can see how it'd be harder to get the drive on due to the Four Winns extended running surface design with the "sponsons" on each side of the transom mount. Might be good for handling but tougher to get in there. That makes getting or fabbing up a rolling jack even more important to make it easier. Using the strap like you have it, there is no way really to keep the drive straight and level, which is what makes it a 15 min job a 2-day ordeal, lol. When we get older my thought is we have just so many years when we can still do this, why do it the hard way? If I do it the easier way I can enjoy doing it a lot longer.
I too used to lift weights in my youth, now I do calisthenics instead of weight lifting, to preserve what joints I have left, lol.
As teenagers we did crazy things, that probably caused later orthopedic problems:
Bench pressing 270 lbs
Dead lift 300 lbs
Clean and jerk, 185 lbs
ah the foolishness of youth and peer pressure...
Lpgc
Nearly decided to take the boat to the river today, instead I started winterising it, so far I've only changed the engine oil and drained water from the block, exhausts and water intake pipe. Tomorrow I'll refill with antifreeze / coolant.
But I did find another problem. The bottom nut on the starboard front engine height adjuster has wound down the stud so the engine is sitting low at that position. This may be why I had such a problem refitting the drive - But if so it begs the question why the alignment seemed OK when I checked using the alignment tool...?
I wonder how the bottom nut wound down - isn't it supposed to be a nyloc nut or are we supposed to use threadlock on it?
I obviously need to wind that nut up... but can I do that with the drive still attached or should I remove the drive first?
While I'm at it should I check the rear engine / bellhousing mounts? I removed and refitted the engine a couple of years ago and seem to remember I had a problem with the rear mounts at that time. Is there any adjustment on the rear mounts or does the bellhousing clamp right up to the inside transom parts?
Lou C
Not sure why the alignment would be OK if that's the case. I think if you change it with the drive installed, it might make things bind, another conundrum to figure out. I never had to do anything with the mounts on my boat so it's hard to say and the Ford mounts seem somewhat different than the Chevrolet mounts that I have. I've had the boat 24 years and the alignment has not changed all this time. I don't think there's any adjustment on the rear mounts, only on the front AFAIK. Can you post up a pic of what the mounts look like? I looked in an OMC parts catalog, but I can't really see it as installed in the boat.
Lpgc
I don't think I'll be able to take a good pic of the rear mounts because that area is mostly hidden by the overhang of part of the boat, the exhausts and exhaust bellows... But I'll try.
The rear mounts should be the same as yours though?
It would be a pain to remove the drive again, don't know whether to remove it before turning that starboard front engine height adjuster nut.
Lou C
The front would be good to see because we can see how the adjustment is made and if you take both sides, you can see how they are different from side to side which is what your concern is. These things often get rusted in place so it's hard to imagine how it moved on its own. On my boat if I ever had to adjust it, I think I'd have to replace the mounts, because I doubt I could get them to move! I do spray with rust dissolver just in case I have to do that one day.
Lpgc
This is the starboard front mount that wound itself down
It was easy enough to turn the nut and wind it back up.. But should I remove the drive again to recheck alignment and see if the input shaft slides into the engine coupler any easier?
I wasn't convinced that checking alignment using the alignment tool worked well even before I removed and refitted the drive this last time. Since this time when alignment checked OK even with the engine much lower at the starboard front than it was before I'm even less confident that using the alignment tool to check alignment works now.
