Woodonglass
- Dec 29, 2009
- 25,927
Re: 1995 Crownline 210 CCR Deck Repair
This should get you started.
Thanks T. I will be checking the mounts before i start putting new material back in, which leads me to my new questions. I've been doing alot of reading on here and...
1) Should i, after doing demolition of old stringers, leave around 1/4" of the channel that the old stringers came out of to use as a guide for the new stringers? You can if you want to, it will not hurt a thing. Others have done it. Make sure to grind the old glass on the bottom of the hull so your tabbing will have good adhesion.
2) I'll be using poly resin for a majority of the rebuild (budget reasons). Once i have the stringers glassed and set in the hull, should i use mat and epoxy (for its bonding qualities) to attach stringers to the hull of can i still use the poly? Poly and Mat will work just fine.
3) Bedding for the stringers??? What is that and what do i do? I assume something goes between the wood and the hull for "cushion"? Need some guidance with this please. I'd Use PL construction adhesive to bed em in! Works great! Needs to cure a few days before you glass em in. Make sure to round over the edges of your stringers, makes glassin em a whole lot easier.
4) Does this sound correct...? cut and form pieces used for stringers and deck, then lay it all out. Coat with poly, then cloth, then wet the cloth making sure to get everything coated (including wood edges)... do this for top and bottom sides. Once everything is in place and deck is attached to stringers, switch to biax for final layer? I would do a dry run on setting the stringers in the boat first, then I'd take em all out, precoat all the wood with resin and a layer of 1.5 oz mat and resin paying close attention to the edges. When dry, I would PL the Stringers in and tab them in and let em set for a day or so. I would then come back with another layer of 1.5 oz of mat and then finish em off with a layer of Biax and call em good. I'd do the same with the plywood deck. Take a look @ MICKS110 thread starting on Page 15 thru 20 and you'll see how to install your deck.
5) Foam floatation... with pour in foam holding water, can i use (should i use) pink 2" thick insulation foam for floatation instead? This is water resistant, correct? Yep, or you could use Pool Noodles. Lot's of guys have.
6) Limber holes, done from front to rear to allow any water intrusion to drain to rear of boat or can i do it from outside towards center of hull? Does it really make a big difference? Not really. I would suggest you get some 1" pvc pipe, drill your holes to fit, and cut the pipe to fit and epoxy em in. You DON'T want any water to get to the wood you just drilled into.
I'm asking this all now because with any luck (and a great amound of help from God) I'll get everything torn out by this weekend and be able to start prep for new material by next weekend.
Keep the information coming...
Thanks to you all.
TB
