Chavez1978
Thread starter- Joined
- Apr 11, 2012
- 55
Hope this is the right section. After struggling with a leak, pulled engine last weekend. Found soft spots on transom, up the stringer and an engine mount completely gone.
5.7L Mercruiser w/ Alpha One Gen II outdrive. I'll post pics following repair also. Took about 5-6 hours to pull the engine...first timer. Not sure if this helps anyone, but I wanted to make it available since I've received so much help from people on here....much appreciated.
Pre-Removal
Outdrive Off
View w/ Engine out
Damaged motor mount...
Pre-Removal
Outdrive Off
View w/ Engine out
