1994 Johnson 70 no power under load
Honorary Supreme Mariner
Does the hose for the telltale come of the side of the block or the top?-----Yes you can do the job yourself.----You need to proceed very carefully and if you come across someting that is puzzling you need to ask.----Too many folks barrel along and make expensive mistakes because they thought they knew how.----Or compare it to automotive work which is not the same.----Also you need to determine the cause / causes of the failure.---You do not want to do this job twice.----There was a service bulletin in 1994 to move the telltale hose outlet .----I am amazed at how many motors have not had this done !
avisalem155
Thanks racerone. I have not been able to check the where the telltale is coming out from yet but will be sure to move it if its coming out the side. I just ordered a head gasket being that the engine definitely needed a new one.
I will see what the shop will need to bore the heads at before I order any parts, but I am seeing sets on ebay for $520 with the oversized pistons, gaskets, bearings.... do I need all of that or can I get away with a cheaper set with less items?
Thanks
????------The process is as follows.-----You do not order parts before the motor is torn down and all parts inspected !!!--Inspect and replace what needs to be replaced only.------If the motor has been run a long time with bad pistons / rings there could be issues with the $$$$ crankshaft and rods too.-----Take your time this is not an instant process !
avisalem155
Thanks for the advice!!! My manual came in (p/n 500609), and I read through the rebuild section and have some basic questions.
1. What special tools will I need, there's a bunch listed but...
2. I do not have an engine lift. Will the engine be too heavy to lift out of place? Maybe with a helping hand?
3. There are many greases, lubricants, and sealants listed. Can you tell me which I will really need? I assume gasket sealer compound, outboard lube, and gel seal? Any easier to find replacements?
There are more questions, let's start with these easy ones =)
Thanks
Faztbullet
Make sure you sand the exhaust bridge as the 1987-1994 are bad about bridge expanding if they overheat and scuff the exhaust side of piston.They wont idle worth a chit and still have good compression...
avisalem155
Will do, thanks for the tip!
Leave the motor on the boat and just remove the powerhead.-----The powerhead itself is not that heavy and most able bodied individuals can lift it off without the use of a hoist.
avisalem155
Ok I will. Any advice regarding tools, lubes, and sealants?
Thanks
Many tools are shop time savers.------You at home can usually figure out how to do the job without them.---------Lubes are not to worry about other that oiling the parts on re-assembly.---Gasket sealer used is permatex aviation sealer.
avisalem155
I'm having problems getting the block off. Looks like it's a bit too heavy/stuck to get off myself. I've taken off all of the screws, and I can push it forward a little to see the gasket separate a little, but she won't give. I'm thinking about taking it to a shop so they can use their engine lift to hoist it out, but I have my trim all the way down and I'm afraid to scratch up the lower unit (all electrical is disconnected)
Any ideas?
avisalem155
Ok got the block out and started further disassembly. I'm up to the flywheel, any good techniques to getting it off?
Thanks
avisalem155
Got everything disassembled and brought the block to the shop to get bored and honed. Trying to get everything cleaned up now before putting everything back together. Advice is appreciated. Will keep you all updated.
jakedaawg
If you have the manual, take that and the crank. Have them mike the crank journals and compare to spec. They are probably fine but whats another $20 bucks at this point. Also, I doubt, from the pics, that you will get by with just a honing. The machine shop may have to bore it over in which case they will probably want youor new pistons to finish hone to, some do some will hone to spec. If your lucky they might even set your ring gap if you bring those also. JMHO, I am sure others will disagree but it works for me, although I do my own rings and honing.
avisalem155
What about for sealing the crankcase? Do I need a sealing gel?
Thanks
Factory " gel seal " or Loctite 518---------Nothing else is to be tried.
avisalem155
Ok so the machinist had to bore it +.040 it must've been pretty bad, not to mention that the Pistons themselves were worse than the cylinder walls...
avisalem155
Hey guys, almost everything is back together again...I have a question, I have the engine bolted back onto the outboard housing, but for some reason there's a huge gap where the block anchor screws into the base...the 6 large screws that screw into the block from underneath (where the cover is) are completely screwed in and the block is flush with the exhaust gasket at the bottom. Any ideas what I did wrong here?
