Rebuilt the engine. Followed break in procedure. Still won't go past 3,000 rpm in forward. Will go to about 4,200 rpm in reverse though. In neutral it will rev as high as I would like. All this was done in the water....now I'm thinking maybe is something in the lower end?
In reverse there is all kinds of exhaust in the water so less load.----------Time to start with the basics.--------check for blockage in exhaust tube.-------Pull carburetors apart and do a thorough inspection.-----------Remove high speed jets for cleaning.-----They are about 3/4" long.
will do. Another thing, where the gearcase meets the exhaust housing, there seems to be a lot of water coming out of there. Is it supposed to be doing that?
Nope it was the top cylinder, motor seized up but I was able to get it loose once I took off the head and used a little wd40. Found pieces of the ring sitting there, afraid to see inside the crankcase
