Does the hose for the telltale come of the side of the block or the top?-----Yes you can do the job yourself.----You need to proceed very carefully and if you come across someting that is puzzling you need to ask.----Too many folks barrel along and make expensive mistakes because they thought they knew how.----Or compare it to automotive work which is not the same.----Also you need to determine the cause / causes of the failure.---You do not want to do this job twice.----There was a service bulletin in 1994 to move the telltale hose outlet .----I am amazed at how many motors have not had this done !
