1992 Stratos 2250 here we go again
Teamster
So I measured my tranom from the top (where the motor hangs on ) to the bottom of boat it measures 28" Should I be looking for a 25" or 30" motor
What is on there now????
I would think about a hydraulic jack plate for the new motor as well,.............
ahmincha
The one on there now is 25" but I do not think this motor was ever ran on the boat. The motor is a 01 boat is a 92 plus only being a 150hp I think it was put on to sell
Teamster
It looks like the cavitation plate is about right in relation to the hull,..........
Have you trimmed it down to see where it lines up?????
That should tell the story on the length yous need,...........
Yeah, I figured you'd sell the 150,.....
I would still think about a jack plate to help dial things in on a day to day basis,......Especially on Erie,........
ahmincha
I looked up the jack plates they look interesting what are the pros and cons of these would i want 4" or bigger
Teamster
A 4 inch would work,...
It allows you to raise or lower the motor while driving to adjust for conditions,..........
ahmincha
Thanks teamster I get what there use is what I was wondering is the benefits from the 4" to 10"
Teamster
The farther back the motor the cleaner the water the prop is running in,..........
jc55
I have a 6" Hydra Jac jackplate with some corrosion if you want to barter. I need someone to hold my hand on Lake Erie this summer and show me the ropes?;) I took it off and bought a new one on iboats last week with the 5% forum discount. I bought the one with the integrated pump "all in one" unit for 300hp from Bob's.
I ran all season with my DT200 and 6" set back jackplate. It's a dream.
I slip my boat in a tributary to the Ohio River and boat out to our island property. The mouth of the creek is as shallow as 2 1/2' deep, even less when they drop the level of the pool. I haven't built a dock on the island, so I beach there and use the jackplate endlessly. I've been able to take my Steiger in unbelievable places and slide the hull bottom right through the mud.
Some cons are,
-You'll have to raise the jack plate slightly to raise the motor all the way up or the steering arm will dig into the transom.
-You're adding another 50+ lbs to the transom
-You're moving the motor further away and as BOB_VT mentioned once, the jackplate works as a lever on a weak transom.
Some pros are:
-I can go anywhere while having the motor in a more upright position
-Get on plane in shallower water (never needed that option)
-As Teamster mentioned, cleaner less turbulent water
-Fine tune your speed and economy per RPM at cruise(which I did finally figure out at the end of the season).
-They're just bad
I'd never go without a jackplate again, but what do I know, I'd mount a machine gun on the front of my boat if I could:laser:...IMO, you don't need the gauge if you can see your motor.
Rickmerrill
Jc that's about as good a jack plate summary as anyone could have come up with!
ahmincha
Thank you teamster
Thank you jc I appreciate the offer But know need to barter for a day on the lake we just got or first hit of snow today so i'm already for spring haha
Teamster
The Cleveland night bite should be kicking off about now,...........
Woodonglass
Hey Teamster, I'd like to invite you to "PIN" youself on our Members Map in the Sticky Section of the Restoration Forum. That way the rest of us would know where you are and if we're ever in your area we could drop by a mooch some coffee off'n ya!!!!;):D
ahmincha
Well I took off the hard top to fit into the high side of my garage. Plus it made it easy to change a couple ballast and light bulbs With the shelves in my garage boat did not quit fit but should fit on lower side now PB150001_zps5b241101.jpg PB150002_zpsa5839eb3.jpg PB150003_zps483037f7.jpg that wind shield is off
kcassells
Well I took off the hard top to fit into the high side of my garage. Plus it made it easy to change a couple ballast and light bulbs With the shelves in my garage boat did not quit fit but should fit on lower side now that wind shield is off
Love that last pic! So I gotta tell ya from the first night pics you showed I thought she was a center console...wrong..oo me. She is a sweet cuddy V walk around!!
I'm in for the ride.
ahmincha
Ok got it on the small side With tank area cover off PB160006_zpsda0ccdc5.jpg PB160002_zps3ba6bddc.jpg Area just aft of tank
ahmincha
Bulkhead forward of bilgeTransom Stringer star board stringer port PB160001_zps8937826b.jpg PB160003_zps5e2d1bec.jpg PB160004_zps235ea3dd.jpg PB160005_zps0b3e27ad.jpg PB160006_zpsa15dc729.jpg
ahmincha
Stringer in area aft of fuel tank star board topport side PB160006_zpsa15dc729.jpg PB160007_zps35093f0f.jpg
ahmincha
Front of stringer at bow where the impact holes are port side PB160009_zps80e8d04b.jpg PB160011_zps7b576181.jpg PB160010_zps5b352577.jpg Front stringer star board side
ahmincha
So as of now I need to repair the 4 small impact holes the front stringer. Tomorrow I will drill some holes in the stringers and transom .
Now I am thinking about drilling large 1" holes around the motor mounting so I can really see whats up then fill with pb
