1992- 70hp/force ,misfire
mobdick10
#1 plug fires good and the #2 weak and #3 fires good, ck/ed the coil by sw. the hot leads from good 1 to the weak 1 and it fired good to so the coil is good, what would couse this 2 misfire?
The Marine Doctor
Re: 1992- 70hp/force ,misfire
Switchbox may have a short to ground.
Stator may not be creating enough voltage and drops off.
You will need a DVA tester to find the leak of voltage.
The Marine Doctor
jerryjerry05
Have you done a compression test? That is the first thing you do when evaluating a problem.Do that and get back to us.J
mobdick10
The Marine Doctor
well i tested the stator all tested 1200 ohms good tested the trigger all tested around 1300 ohms also good, d/sided 2 test it while running it will run just wont smooth out ,backfires and no high rpm's, so anyway the blk/wt wire from the trigger i accidently touched the test lead 2 it and ground and smoothed out, is it possible its needs an external ground from that wire ? by the way jerry the compress. was good ,ow i'm up the road from u in palm bay/malabar.
