FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
#1 plug fires good and the #2 weak and #3 fires good, ck/ed the coil by sw. the hot leads from good 1 to the weak 1 and it fired good to so the coil is good, what would couse this 2 misfire?
well i tested the stator all tested 1200 ohms good tested the trigger all tested around 1300 ohms also good, d/sided 2 test it while running it will run just wont smooth out ,backfires and no high rpm's, so anyway the blk/wt wire from the trigger i accidently touched the test lead 2 it and ground and smoothed out, is it possible its needs an external ground from that wire ? by the way jerry the compress. was good ,ow i'm up the road from u in palm bay/malabar.
