Hello,
I bought this boat for a $1000.00 from a friend. I purchased s Clymer boat manuel for it. From what I have read this I/O has a a B rating along with the L-Drive, but parts are cheap and the engine is easy to work on. I plan on doing everything on the restore. I replaced the impeller, it was shot, changed the gear oil, the old oil looked good no water or metal. charged the batteries, brushed up the electrical on the starter ect.
The neutral button was not working and shifter was hard to push on the remote. There was a small piece of metal broken on the inside the shifter housing that i removed and the wiring was not in the handle right, and easy fix.
I got the engine to start with the old plugs and seems to run fine in the driveway. I will post a video of that, I think it sounds ok.
I proceeded to rip out the old soft deck. The stringers and transome are good. I will replace the deck with marine plywood cover with fiberglass and west systems epoxy.
I am not sure if i want the box seats back in. I would rather put pedestal seats in to open up the deck.
I ripped out a lot of foam and plywood.
Do I need to put all that foam back in the boat? What about the foam around the engine box? Some the foam was water logged. I would rather not put new foam back in.
I would like your opinion. Also not sure how much time and money to put in this because of the reputation of the l-drive.
Any deck layouts would be plus if anyone has pics.
Thanks
Thanks
