ezez
Thread starter- Joined
- Jun 3, 2009
- 122
I have a 906x91c that is having issues at high RPM cruising on the water. At high RPM the motor misses intermittently and it appears to get worse as the motor gets warmer (this might be my imagination). This miss doesn't impact the ability to maintain overall speeds and the boat is still serviceable but something isn't right.
I really don't know if it is an ignition or fuel delivery issue. I have slapped new plugs and a new fuel diaphram in it and the symptom persists. Also, a compression check is a little less than promising as it reads 100/120/120 moving down the motor.
My next steps in order:
1) Decarb motor
2) Rebuild carbs
3) Have coils checked as I don't know of a way to check for missing intermittent voltage/spark
Any help is much appreciated!
1) Decarb motor
2) Rebuild carbs
