Woodonglass
- Dec 29, 2009
- 25,931
Re: 1990 skeeter s-130 stringer/floor replacement.
That's called your Eye Bolt. The Bondo Resin from HD and Lowe's has wax in it. This means if it dries, you must sand the previous lamination before you can lay another layer over it and wash it down with acetone. It does not adhere as well as regular laminating resin. The 1708 it stronger than normal woven roving.
