1990 Lund Pro V fuel tank
redarndt
I'm going to do a lot of repairing on this boat. Started with replacing a few floor boards. Turning into a much bigger project.
Is this gas tank supposed to be sagging? Should I just keep it in there or try to replace it? It's sagging at least an inch in the middle.
redarndt
Can you inbed photos in the thread with a mobile device from photobucket?
20160203_212833.jpg[\Img]
GA_Boater
Welcome aboard.
If you can click the IMG code box in OB and paste the code in your post on your mobile, then yes. Just what I did.
Plastic or aluminum tank? Was the deck collapsed over the tank? Anyway, it shouldn't be smushed down like that.
GA_Boater
Looking closer, I see it is a poly tank. Still it's not right.
redarndt
Yes. It is a poly tank. The deck was not collapsed above it.
Anyone had any luck finding shallow below deck gas tanks?
My dimensions are 59" long x 6.75" deep x 19" wide. The bottom corners are also angled a little bit but mostly flat.
aiX0rzuN9m4XlRAuQSNygPQZX21QgwKvwJmjKPynlK2
jbcurt00
Does Amazon give you an IMG code choice when you click Share?
If so use that not link.
Pix should show up IN your post like it did in mine, and not attachments or links that have to be opened.to be viewed.
redarndt
It just says "Get Sharable Link" I'll use photobucket! Looks simple enough
Photobucket Test:
jbcurt00
And thats why I use and recommend it....
You need to know that if you setup up folders at PB, and move pix around into different folders, if you've linked the pix somewhere, and then move it to a new folder the pix link does disappear and back to blank squares instead of pix in your posts.
So I dont post pix until its in the folder I plan to leave it in.
