1990 Evinrude 25 HP E25RESB Low idle problems
tom071984
Re: 1990 Evinrude 25 HP E25RESB Low idle problems
when I do use it (I really never have to) when I pump it I see small air bubbles going in with the gas in the little tube to top of the carb.
Pull the wee line off the carburetor when the motor is running.
tom071984
When the motor is running that line does not move gas....I can tell because there are tiny air bubbles in the line when I press the primer.
tom071984
Outboard Motor Repair- 35 evinrude won't idle
This article has me thinking....I do not remember seeing part #10 when I tore the carb apart for cleaning....there was no o-ring inside of there...also part #13 says it is also an o-ring...I think there might have been a washer there...
http://www.**********/parts/search/BRP/EVINRUDE/1990/E25RESB/CARBURETOR/parts.html
I ordered a carb rebuild kit Sunday and it should be here Friday. Would part #10 and #13 be in it?
tom071984
Dumb question but does this motor have a fuel filter? I never saw one while working on it.
Bosunsmate
front part of fuel pump has it
tom071984
increase idle without opening butterfly
tom071984
does this model have a timing advance screw? Also does anyone know what the timing is supposed to set to?
James R
Sounds like air is being sucked in through the primer. When the motor tries to stall try spraying a little fuel mix into the carb throat.
If it picks up you could have air leaking in or the idle jet is blocked.
tom071984
I jumpered a spark tester up while running the engine today and it appeared that the bottom plug was misfiring. The spark was not as good as the top plug either. Not really sure how to trouble shoot from here.
tom071984
Where is the idle adjustment screw on this engine? It is a tiller steer, pull start...thanks
Did you ever resolve this?? I am having trouble with my '92 E25ELENS
Runs at full throttle all day long but won't idle any more.
