1990 200 johnson overheating
tonkatoy352
I just bought this 25' proline and took it out ,ideling out channel the temp gauge went up to high side of normal and buzzer came on.so i shut the motor off waited five mins and started again did the same thing so i took it back in. changed impeller today and on the ears for five minutes did the same thing water was warm but not real hot. what do i do or what could be problem thanks tonka.
bernd64
Re: 1990 200 johnson overheating
suck thermostats clogs inthe powerhead and more
bernd64
you have the motor in salt water ?
bernd64
salt will buld up in the motor over the time and clog the water lines.
is the motor peeing water?
bernd64
ok my best guss is the heads a cloged up with salt .
bernd64
IM me and i tell you something
