BayouWaters
Thread starter- Joined
- Jan 29, 2017
- 78
Kcassells - thanks for commenting. I tried the sealing of panels on a table and I find it easier to do it in the boat. On a table I can only do one side at a time, wait for it to kick, flip the panel and do the same, then grind/trim any overage before installing. When I do it in the boat I start at the front and work my way back with sealing and tabbing all at the same time with no waiting and no material waste. As far as sealing the edges, if you look closely at the installed panels you will notice a dark band around the perimeter. This is 2 coats of raw resin follow by a thin coat of thickened resin made from resin, cabosil, and milled fiber. Makes a caulking like consistency and does a great job of sealing all gaps on the end grain before installing.
