1989 SeaRay 230cc transom replaced
islander1013
Hi Guys, By any chance does anyone know where I can get a Mercruiser Transom template
Mod EDIT: Removed solicitation
Also i just had the transom replaced on my 1989 SeaRay 230cc. the guy that did it replaced the transom from the inside however their were some tiny cracks on the outside and when he repaired those he filled in the holes that were originally in the outer core. When i drill the new holes thru the transom are they drilled on an angle?
jbcurt00
I saw you posted that you couldnt get the template to download. The one shown template is an image.
Right click the image, select view image. Save the image. Then you can enlarge the image to read the dimensions.
Yes, you will have to make your own 'template' but that image has all the necessary info to be able to do that.
W the image, you could also spend a bit of time to enlarge the image until the printed image's dimensions exactly match the listed dimensions.
