Re: 1989 Regal 185 Mercruiser starter solenoid?
OK, with the ignition off try this: On the slave jumper between the large terminal with the red wire and the small terminal with the r/y wire from the switch. The solenoid should click, you should have 12V on the on the large r/y terminal and the starter should turn. Make sure that the large r/y wire is connecter to the s terminal of the starter.
