solar7647
- Apr 23, 2009
- 1,218
Re: Need some advice on remodel
Yes, you just cut then to fit the area. Some people stack them and leave them loose others will glue them together so they don't move around really dosnt make a difference since they will be in a closed in area.
In my opinion those pieces your talking about have no strucual value and it will be fine to cut out. I think the reason they are like that is to provide additional flotation foam in thevrear of the boat.
How do you test to see if your transom is rotten? Hopefully its a dry day tomorrow and in the afternoon I can get started on ripping the floor up. When you guys say to use the closed cell panels from home depot, your suggesting just cutting the pieces to fit in between the stringers?
We are thinking that the seat bases are made out of wood and are just fiberglassed in next to the sidewall and appear just to be apart of it. The seat bases themselves appear to be a seperate piece its the little side piece that comes off the sidewall I am scared of. I seen one guy who left these, put a stationary single seat on the front then built a rear bench that had cushions to cover the back of the base to give the whole back a "c" look. Might be a possibility.
