1989 force 125 wrist pin help
trioval00
ok, I need some help or advise.......
I have a blown Piston and need to remove the wrist pin so I can install the newer piston.
how do you press this out?
Mark
pnwboat
Re: 1989 force 125 wrist pin help
I've used a 2 ton press like this.
Took everything I had to get it done though. I used the Wiesco forged pistons as a replacement which use "floating" wrist pins and keepers. Pins go in with just finger pressure with circlips to keep the pins in place.
If your using "pressed pin" replacement pistons, there's a special wrist pin bearing spacer tool to keep from damaging the wrist pin bearings or getting them bound up.
