edmaude
Thread starter- Joined
- Aug 24, 2008
- 28
Recently purchased a 17 foot Whaler with an 89 Evinrude 100XP Commercial engine on it. Overall, it has run great the 6-7 times I have had it out, however I have a few issues I need help with
1-Ran 6 gallon tank and 1 can of seafoam through engine Friday to remedy some poor idling. Boat ran fine, but cut out and would not start minutes after I switched back the the regular fuel tank. Got boat home and it started on first crank when I ran on flaps in driveway. Had it out for a few hours yesterday trolling and cruising with a few starts and stops and it ran best yet since I have owned it. What could have caused the no start, vapor lock?
2-Have noticed black oil leaking from where shift rod goes into lower unit. Noticed after I have run boat a few hours and then taken home and parked driveway with motor tilted up. Nothing to the point it drips on ground, but a few inch streak.
3-Oil also is leaking from top of engine down under the plastic housing that covers mid section. I took off the plastic cover and looks to be coming from somewhere up in engine itself where I am unable to see and get to. What could this be?
The waterpump and VRO system were replaced in 2007 by prior owner and overall the engine runs well after 2 Seafoam and gas treatments. I have noticed though that the alarms are not working as I do not have a beep when I move key to start position
I am new to boating and could use whatever advice you guys can throw my way. I would also like to find an Evinrude Tech in Northern NJ to give this motor a thorough inspection and service
Thanks,
Ed
Thanks,
Ed
