1989 bass tracker hull crack repair???
claytonhaske
hello, i have a 1989 bass tracker pro 17 and it very slowly takes on water through a small crack in the hull on the underside of the boat. it is about 4" long and it runs through some rivets. i read somewhere that this is a common problem with these older bass trackers. so if i couuld get some advice as in how to repair it, that would be great. thanks, clayton
oops!
Re: 1989 bass tracker hull crack repair???
what exactally are we looking at?....is this a glass boat with some rivits?.....it looks like gellcoat....but the picture is kinda blurry
claytonhaske
its an all aluminum boat, the crack you see is running through 2 rivets.
claytonhaske
should i use 5200??? or take it to a welder??? thanks, clayton
Woodonglass
Honorary Supreme Mariner
Do you have access to the Crack from the Inside of the Boat?
claytonhaske
i will have access in about a month, when i redo the carpeting. i want to get all the stuff to do it, so when i go on vacation and i have time to do it, i will be prepared to get it done.
Woodonglass
Then check out a product called Coat-It. It will do the Trick for you...
