MrDrysdale
Thread starter- Joined
- May 24, 2008
- 1
Thank you in advance for any help. I have read many posts, have found none with my problem. I have the Design 1, 3 Ram / 3 Wire Trim/Tilt system with the SIDE FILL Reservoir and the square motor. After removing the 2 Allen head screws holding the motor in, I was unable to remove the motor, so I removed the 4 long screws that hold the motor housing to the base. This allowed removal of the motor and revealed 3 screws holding the base to the pump cartridge. I removed the 3 screws to get the base off the pump; there are 2 O-rings under it and 1 is broken. I put 12 Volts to the motor terminals to test it in both directions; it just hums, won't move. All replacement motors I have found on line for this unit come with the cartridge pump attached along with the motor. (Arco part # 6278. The #6277 is motor only, but says "Will not replace original equipment." The #6279 is motor only but it is for "Design 2 with Aft Fill Reservoir") My problem is I can't get the old pump cartridge out of the housing to be able to use the Arco #6278. I screwed the base back on and pried on it but it seems like the base is going to break before that pump ever comes out. Is there something I'm missing here? I can't find a way to free the cartridge from the pump housing. I can't buy just a motor to replace my old one and I can't remove the old cartridge so I can buy the Arco #6278. Again, any help will be greatly appreciated.
