spectrum14
Thread starter- Joined
- Aug 2, 2009
- 18
Hi, I have a 1988 50hp johnson. I think i probably have more than on problem, but i don't really have any idea how outboard work. I guess ill just give a run down of what i have to do to get the motor running and going. To get it to start are after couple of days you have to pull the cold start lever all the way up and choke the hell out of it, and once it starts you have to keep pushing the choke or it will die. The cold start lever is up the whole time. After a while of this it gets warmed and and i push down the cold start lever and go, but i can't let it idle. I have to take right off. Once i start moving it seems to run good and i run it to the other side of a small lake. It seems to have a lot of power. When i come to a stop it will idle really high for a while and then sputter and shake then die. To get is started again i have to pull the cold start lever and choke the hell out of it again. I think all of the basic stuff is ok, but i am not totally sure. I just checked the compression and it was 110 top 130 bottom. I thought that was kind of a big difference, but im thinking that isn't my only problem. Help
Thank You
Thank You
