1987 evinrude 150 trim problem
larrypressley
the problem i am experiencing is that i can tilt all the way up and down as long as i am sitting still or putting along. once i throttle up to take off, the tilt stops just as i get on top of the water. it only tilts up just about 1/4 of the way or so. this makes for a very bumpy ride as i am sure you can imagine, and is very frustrating as i cant continue with the boat hopping dramatically. i have checked the fluid level in the pump. when i took out the screw, fluid was escaping so i have to think that it has enough fluid. i checked all of the valve and seal screws for tightness as i thought it might be sucking air or allowing air to escape depending on the assignment of the individual mentioned parts. i thought i might have a weak battery, but they all test out good. i am very frustrated and dont know what else it might be except the tilt motor may be going bad and it only shows up under a load. can anyone help me with, or give me some advice about this problem before i take it to the dealer and shell out lots of money for them to figure it out? i would greatly appreciate any and all help and opinions! thank you all ahead of time.
Joe Reeves
Re: 1987 evinrude 150 trim problem
That unit has 15 degrees of trim which holds under pressure, and the rest is just tilt which does not hold under pressure.
larrypressley
wow! that is over my head admiral. sounds like you know what you are talking about so i will ask, if you dont mind; to clarify this to a layman please. i think you are on to something.
boobie
Joe told you just the way it is. The TILT doesn't work under full power, but the TRIM will and only go so many degrees up.
Will Bark
Tilt won't hold motor up under power and the trim rams will only raise 15 degrees; raising the motor up more than that will cause the boat to bounce all over the place.
larrypressley
ok. thank you for that clarification sir.
larrypressley
i understand that your questions require answers sir. however i did not recieve any questions to answer. i only recieved this latest reply. and i thank you for your reply sir.
larrypressley
thank you for further helping with the other guys clarification. it was not clear to me at first what they were talking about. now i realize that they think that this is my 1st rodeo. the thing is sir, this is the third season i have had this boat and this is the first time that i have experienced any problem of this type. i was only trying to figure out why. i hope that i haven't seemed ungrateful or even stupid for asking for clarification. it just does not make sense to me. thank you for your time sir.
emdsapmgr
The power trim range is the first 15 degrees of movement measured from the tuck position. The engine is lifted by the twin chrome pegs of the power trim unit. These dual pegs have the ability to move the engine in any 0-15 degree angle when under full power. From 16 degrees and up, that is the "tilt" position/range. The large single cylinder moves the engine through the "tilt" range. The tilt position can be used for running at idle in shallow water areas-but not under full power. If you hit full throttle in the "tilt" range, the (single) tilt cylinder does not have the ability to hold the engine up. The force of the prop will easily overcome the lifting ability of the single cylinder. The engine will force the trim fluid around an internal bleeder valve and the engine will move quickly downward till it hits the two trim pegs. This is normal operation for any tilt/trim system.
larrypressley
thank you for breaking that down for me sir. this is definitley helpful in understanding how the whole tilt/trim system works. i just dont understand why it isnt working correctly. i am throttling up with the engine all the way down to where the trim bottoms out. as soon as it gets on top of the water i start trying to trim it up to steady the boat from bouncing. the trim comes all the way up but there is no angle within the 15 degrees that it will trim the boat out. just stops at the top of the 15 degrees as it should. i just dont understand why i cant seem to trim out as in 3 years of running this boat, i have never had this problem. always popped up and trimmed right out, no problem. have you ever encountered or heard of this problem before?
Joe Reeves
As soon as it gets on top of the water i start trying to trim it up to steady the boat from bouncing. the trim comes all the way up but there is no angle within the 15 degrees that it will trim the boat out. just stops at the top of the 15 degrees as it should. i just dont understand why i cant seem to trim out as in 3 years of running this boat, i have never had this problem. always popped up and trimmed right out, no problem.
Larry... Your last post indicates that in the past 3 years, this engine being on the same boat, it has performed as it should pertaining to the tilt/trim unit....... meaning that this same engine, tilt/trim unit, boat combination could be trimmed out to a degree whereas you obtained a normal plane (angle of attack).
This bouncing... I assume you're not speaking of a high rate of speed in rough water. Any rig is going to bounce in rough water. I picture in my mind a condition we call purposing.
If this was a case of transferring the engine over to a different boat... a boat that might have a different angle of attack (bevel) to the transom, I could understand the problem. This would bring up a case where one would need to install adaptors/shims between the transom brackets of the engine and the transom to modify the angle of attack of the engine.... something you may still need to do. The shims are a accessory, needed for various boats so rest assured that they can be purchased at your dealership or a marine type store.
Starting from scratch, engine in water or not, makes no difference, BUT engine NOT running. Engine trimmed all the way down. Observe engine and press the trim up button... notice the rpms of the PTT motor and the speed of which the engine is rising. At the 15 degree mark, the sound/rpm changes and the engine starts to raise more quickly. Okay, that gives one a good idea of the trim vs the tilt position and function. What will hold and what won't.
If, as per the immediate above paragraph, the PTT unit functions as it should, having the 15 degree trim movement, then going into the tilt movement, and NOT losing pressure in the trim area while underway.... the problem would need to be with the boat, not the engine, and this is normally due to being trailered or set up on blocks (stored) incorrectly which leads into forcing the hull to develop a hook.
Looking at the hull bottom from a side angle, a hook of the hull can usually be easily observed.... the front of the hull goes back normally for a distance, then raises a bit as one looks towards the transom, then lowers back down (the hook) to its normal depth as it nears the transom. This causes the boat to plow, bow down, and if fast enough, to become air borne only to plow down and continue the cycle.
If no hook exists, and hopefully it does not, and the 15 degree travel of the PTT is holding as it should, has anything been done to the engine or boat that could possibly result in the rig moving faster... becoming air borne? At any rate, something has changed and it seems to me that the cure is to have the shims installed in order to have a greater amount of upward trim movement.
Hopefully this has been of some help to you.
larrypressley
ok. that is the next place to look for sure. i hope it is not the case but who knows until i check it. thank you joe. you have been very helpful.
larrypressley
i'm sorry joe, i did not answer all of your questions. the engine is on the same boat and i have not done anything to the boat except install a water pump late last summer. the boat was stored on it's drive on trailer over the winter. i will check the hull though and let you know if i see a hook. thanks again.
emdsapmgr
After re-reading your post, it is likely that your trim is working normally. Despite that, you seem to be having a new planing issue this season. Possible that something has changed with the boat. A couple of questions: 1. If one spark plug is not firing, the engine will not make power. Check for spark on each plugwire after the engine is thoroughly warmed up. 2. Is the rubber hub in the prop bad? 3. If the prop edges have burrs, this can cause caviation. 4. Any chance that the hull is waterlogged? An extra 500 lbs of water in an under deck compartment will change handling characteristics.
larrypressley
i did put new spark plugs in the engine this spring, but i did not check them for spark. the engine was running a little rough with the 2 year old plugs. upon replacing them with new ones, properly gaped, it ran great. i guess a spark check couldnt hurt though. i will do that. as far as waterlogged hull, i have not seen any sign of any water below the deck. i watch the rear area for water every time i put the boat in the water just to make sure it is not taking on any water due to its age. i also raise the front of the boat with the boat jack when it is parked so that any cover leakage from rain can drain out of the rear. the prop looks good, no burs. the prop is tight and has no detetctalble play. is there a better way to check this rubber hub? if so how do i do it? these are all very good and valid points which i really hadn't given to much thought till now. thank you so much for taking the time to help. i will let you know if there is a spark problem as soon as i can check it. thanks again.
Joe Reeves
Propeller slippage check: Remove prop nut, with a magic marker, mark the hub and propeller with a straight line, reinstall prop nut etc, test run engine in water. After test run, remove prop nut and observe the marks. If the marks are now out of line, the hub is slipping within the propeller.
The symptoms of a slipping prop is that at a certain rpm (changes as damage increases) the engine speeds up and the boat slows down.
Since you made no mention of a power loss, I assumed that your engine was running normal. If you have a tachometer, were you still obtaining the normal rpms that you usually hit?
I usually recommend that the first thing a member does is to check the compression and spark on all cylinders BUT your question was more pertaining to the function of the PTT assembly so I traveled down that road.
However, member "emdsapmgr" has brought up a excellent point which should be looked into just in case.
Remove the spark plugs and leave them out for the compression and spark test. Do the spark plugs all look alike, what do they look like?
What is the compression reading of each cylinder?
The spark (with the s/plugs still removed) should jump a 7/16" gap with a strong blue lightning like flame... a real SNAP! Does it?
(Spark Tester - Home Made)
(J. Reeves)
You can use a medium size philips screwdriver inserted into the spark plug boot spring connector, then hold the screwdriver shank approximately 7/16" away from the block to check the spark or build the following:
A spark tester can be made with a piece of 1x4 or 1x6, drive a few finishing nails through it, then bend the pointed ends at a right angle. You can then adjust the gap by simply twisting the nail(s). Solder a spark plug wire to one which you can connect to the spark plug boots, and a ground wire of some kind to the other to connect to the powerhead somewhere. Use small alligator clips on the other end of the wires to connect to ground and to the spark plug connector that exists inside of the rubber plug boot.
Using the above, one could easily build a spark tester whereas they could connect 2, 4, 6, or 8 cylinders all at one time. The ground nail being straight up, the others being bent, aimed at the ground nail. A typical 4 cylinder tester follows:
..........X1..........X2
.................X..(grd)
..........X3..........X4
