1987 evinrude 150 trim problem
larrypressley
Re: 1987 evinrude 150 trim problem
Propeller slippage check: Remove prop nut, with a magic marker, mark the hub and propeller with a straight line, reinstall prop nut etc, test run engine in water. After test run, remove prop nut and observe the marks. If the marks are now out of line, the hub is slipping within the propeller.
The symptoms of a slipping prop is that at a certain rpm (changes as damage increases) the engine speeds up and the boat slows down.
Since you made no mention of a power loss, I assumed that your engine was running normal. If you have a tachometer, were you still obtaining the normal rpms that you usually hit?
I usually recommend that the first thing a member does is to check the compression and spark on all cylinders BUT your question was more pertaining to the function of the PTT assembly so I traveled down that road.
However, member "emdsapmgr" has brought up a excellent point which should be looked into just in case.
Remove the spark plugs and leave them out for the compression and spark test. Do the spark plugs all look alike, what do they look like?
What is the compression reading of each cylinder?
The spark (with the s/plugs still removed) should jump a 7/16" gap with a strong blue lightning like flame... a real SNAP! Does it?
(Spark Tester - Home Made)
(J. Reeves)
You can use a medium size philips screwdriver inserted into the spark plug boot spring connector, then hold the screwdriver shank approximately 7/16" away from the block to check the spark or build the following:
A spark tester can be made with a piece of 1x4 or 1x6, drive a few finishing nails through it, then bend the pointed ends at a right angle. You can then adjust the gap by simply twisting the nail(s). Solder a spark plug wire to one which you can connect to the spark plug boots, and a ground wire of some kind to the other to connect to the powerhead somewhere. Use small alligator clips on the other end of the wires to connect to ground and to the spark plug connector that exists inside of the rubber plug boot.
Using the above, one could easily build a spark tester whereas they could connect 2, 4, 6, or 8 cylinders all at one time. The ground nail being straight up, the others being bent, aimed at the ground nail. A typical 4 cylinder tester follows:
..........X1..........X2
.................X..(grd)
..........X3..........X4
joe; thank you for the information on how to check for prop slippage. i will certainley do that. that sounds easy enough to do. i am not aware of any power loss though. the rpm guage still shows consistent readings under operation and under a load. i am not sure how accurate the guage is as it is the original one from 1987. but a spark plug check and a compression check is still an excellent idea. the boat has only been run a few times since i put the new spark plugs in this spring but that should certainly be enough to tell if there are 1 or more that are burning fuel differently. i will perform these test's this weekend and keep you posted on the results. thanks again joe. once again, you have been very helpful.
