BSnB
Thread starter- Joined
- Jan 8, 2007
- 281
Re: 1987 28' Chris-Craft 283 Amerosport
The lights I bought are exterior waterproof RGB LED's. The connectors are clearly not waterproof, nor would the transformer be, but I wouldn't use the transformer anyway and I'll solder the wires rather than using the connector. I've got this hairbrained idea of using one strip of these lights and mounting them in a rigid sliding door type track along the stern to provide underwater light. I'd make my wire penetration above the water line and run the wires to a switch on the dash with the controller receiver up there somewhere too. I figure it will take maybe half of the 16 foot length of lights for the stern leaving me another 8 feet or so for topside accent lighting.
The notch in the stern that I was talking about, chriscraft254, can be seen on my signature photo. You can see where the swim step extends out over the water. The notch is that right angle formed in profile below the swim step where it meets the stern.
The trials and tribulations of the Amerosport 283 might be too limiting, LOL. I'm not doing amazing things with fiberglass or tin like you or other iBoaters. Maybe my contribution on here is simply to describe the trouble that can come from a hairbrained idea carried out by the hands of an overconfident backyard "craftsman".
Ok, I'm climbing aboard my Chris Craft friend. Your thread should be rename "trial and tribulations of the Amerasport 283". lolyou have had your hands full sounds like. I like the story on the lights also. Did you get the interior lights or exterior. Should not need a ac/dc adapter.
Just a couple thoughts. The table that you are veneering, you could veneer the sides, veneer the top and then add a oak,mahogany or teak L trim around the top edge. No matter what you do with a raised edge, if rough enough things are going to tumble, my thought is its not worth it to raise the edges. I like laying my arms up on the table sometimes, and a flat surface is mors comfy.
As far as the top goes, great idea to put a hardtop on her. The more head room the better. Might offer some rod storage above your head also. I like the first drawing with it up higher. Can you post a pic of your stern where the knotch is, I have some ideas for you there, just don't know if they will work until I see a pic.
Great thread man, you do have good story telling capabilities. I will be following your progress.![]()
