BSnB
Thread starter- Joined
- Jan 8, 2007
- 281
Re: 1987 28' Chris-Craft 283 Amerosport
Thanks for the compliments on the storytelling. It's easy to do when it is a great story!!! I may have to follow up with the story of why we moved the boat from Homer's slip!
Homer really is a great guy. I want to think that he was just going through a run of bad luck. I checked his work on the fuel/water separators and they are perfectly done. I have had a problem with the water heater though. I think the thermostat is bad too because the pressure relief valve will blow if I leave the water heater on for a good amount of time without using the water.
I've crawled into every inch of the engine compartment and found everything to be well installed and well-secured. I even discovered another Danforth Anchor, with chain and rode, mounted and secured alongside the water heater. Looks pretty clean too! ;-)
I've posted a couple of before and after pictures in a thread started by another guy here who is renovating an Amerosport 284. Apparently there are 3 of us who have bought these Amerisports within the past couple of months. Because this thread has turned out not to be a renovation/restoration thread, I'll post the restoration pictures there and keep this thread going with stories of a "new" boat owner.
