1987 130 v4
whatsagm
Just picked up a boat with this Yammy on it, seems to run good. My question, lower unit has been welded and I want to install a better lower unit in it. I have worked on plenty of mercs and Johnson/Evinrudes, my question is when pulling lower unit does it have to be in gear or neutral? Also any input on the outbound in general would be awesome. Everything I have read says they are good reliable outboards. Thank you for any input
99yam40
look to see if that old motor has a push pull shift shaft or a twist like the newer ones.
if a push pull, find out where the joining nut is and how to get to it.
some required to be in reverse to be able to undo it
