1986 Blue Fin Gas Tank Location?
idaho4fish
First post, looking at a clean 1986 Blue Fin 18' with a 90 HP Yamaha 2 stroke
​Question is, the owner has 2 gas tanks up high on the transom, (left/right) is this right?
Was there a single tank on these? located behind the sliding doors in stern?
​Thanks
jbcurt00
Yes, its unlikely Bluefin used 2 high mounted tanks originally, much more likely to have had just 1 below the splashwell behind the sliding screen.
idaho4fish
Hey thanks
Previous owner says that how he bought it
Any idea fuel capacity originally?
I will post a pic soon
kcassells
Whatever tank you buy to fit the area on deck will do. Try to center it. I always like as much fuel as possible.
idaho4fish
Yeah, I see Mueller has some...
Any risk of leaving tanks up high on transom
​I am not able to post pics yet ???
kcassells
Supposed after 3 posts you should be able to post pics.
Pics definitely help.
idaho4fish
[/IMG]
pic
idaho4fish
I keep getting the "you are not authorized to edit or create attachments" when I try to post pic ?????
idaho4fish
No Title
Thank you jbcurt
GA_Boater
Welcome aboard, Idaho.
I tried to enlarge and it won't let me. The sideways pics - No idea.
That is not where the tanks should be. They don't look strapped down, are they? Inventive PO, but not a good one.
Won't the tanks fit under the splashwell?
idaho4fish
Thanks
OK figured it out, click on pics and they enlarge/needed to resize in my editor- good to go
​Not sure about fitment, PO tells me that was original tanks...
​BF has been very well taking care of and for $4K it get me in the water
​I can rectify tanks if they will fit under splashwell, is this dangerous as is ???
Renderwurx
​Thanks
My 88' Bluefin 19' Sportsman (18'10") had the tank in the nose. It is a 19 gallon tank. If yours had one, it would liekly have the metal clips (one on each side) or the remnants of them. You can zsee them in this pic... clipping over the tank to help hold in place.
idaho4fish
Render,
Thanks for pic, My offer to buy is contingent on passing a leak down test on yamaha motor.
From the info I've got so far from here I am going to dig a little deeper and really look hard at flooring under splashwell area.
I might be missing this weakness as the reason for the tanks not being under there or they just wanted more storage?
PO is like the 3rd. Or 4th. Owner, so it may be the way he got it as well and didnt know better?
I will look under bow area as well to chech for tank there
As long as flooring is ok, I am not to worried about relocating or buying tank (s) to put behind screens
I have learned alot from this forum so far
I really dont think there is a big cost impact here for gas tanks is there?
Renderwurx
It is likely the original tank and/or hose degraded to the point of not being usable. Instead of fixing it either out of laziness of thriftyness, they opted for the tanks you see now. Why not below? Perhaps easier to fill, they had the short line on hand and it wouldn't reach if left lower. Perhaps they were worried about tank venting in the enclosed area and igniting.
I'd guess it was more of a jury rig and go fishing kind of thing. I have seen some go with a belly tank placed where the ski locker is. FOr me, I want to stick with the front mounted tank to offset the weight and help with the boat getting on plane and how it sits when fishing.
idaho4fish
Well, yeah PO finally admitted he moved tanks from under splashwell
The screen doors are open to the left and will not budge?
Noticed oil stain back in there he claims he spilled 2 stroke oil
That and the screen doors not budging has me wondering about floor in area?
The floor against transom was warped up a little?
Performed leak down test, center cylinder was 18-20% on 3 tries
The other 2 cylinders were rock steady with no leakage?
Not feeling vey warm and fuzzy?
