1986 Achilles Dinghy Floor Restoration
Kmg3356
Finally after all these years the wooden floor on my dinghy has fallen apart. I called Achilles and they wanted $350 for new boards and plastic slats. I ened up cutting new boards and my question is... What should i put on them to seal them from water ? The West System is too expensive..Any suggestions would be greatly appreciated. ...
Thanks,
Keith
Bob_VT
Re: 1986 Achilles Dinghy Floor Restoration
Welcome to iboats!
Post a few photos. $350 :eek: Want to seal up a few boards.... standard fiberglass resin available at walmart or any auto parts store will work. You can get away with a thinner sheet of plywood (exterior grade) sealed with fiberglass resin and a covering of fiberglass cloth on one side.
If you want a non slip... there are things you can add to make it non-slip but do not just add sand. You would create a deck board that will shred anything that comes in contact with it.
I bet you can accomplish everything for half the money or less.
Kmg3356
Thanks Bob,, I ended up using regular plywood and did put a resin on it.. so far so good . The resin was expensive.. $24 for a quart..
Keith
