1986 6 hp evinrude no top end
grizzlyadams73b
got the motor to idle and runs pretty good. but thee seems to be no top end. doesn't wind up like the 9.9 i also have. plugs are properly gapped. any ideas?<br /><br />thanks
D
DJ
Guest
Re: 1986 6 hp evinrude no top end
Griz,<br /><br />It won't wind up like a 9.9. It's a different animal.<br /><br />Has it changed?
grizzlyadams73b
just bought it. doesn't seem to have the rpm it should. no power band.
CATransplant
Sounds like it's time for a good tune up, eh? It sounds like it may be running on one cylinder. Start by checking spark, compression, then move on from there to the carb, if necessary.
CATransplant
Actually, I had a wind-up outboard when I was a kid. It came with a little metal boat. You'd wind up the outboard, then it would run around the bathtub for awhile.<br /><br />Musta been where I got my attachment to boats.
grizzlyadams73b
just had a carb kit put in it last summer and compression check. never really got to run it after that.<br />didn't run when i bought it so don't know what it should run like. and the former owner is deceased. runs good and idles down to a purr but just seams to lack the rpm at full throttle.
CATransplant
Check the spark. Try running it open throttle on the water and use a WELL-INSULATED pair of pliers to pull one plug at a time. If one plug wire off doesn't change how it runs, you've narrowed it down.<br /><br />Your 6 hp should run up to about the same RPMs as your 9.9. Something ain't right with it if it doesn't.<br /><br />It's a two-cylinder motor, just like the 9.9, so it'll sound about the same at the proper RPMs.<br /><br />When did you put new plugs in it last?
