1985 Johnson 30HP Carb Rebuild
Marianne
Hello All - I've picked up my new carb rebuild kit from the marina. Armed with a can of carb cleaner and some tools I think I can get it off. Unfortunately I was shipped the wrong manual ... can someone let me know what comes off first ? So I can get to the carb. Looks like the starter has to come off too ?
Please advise,
M
Harker
Re: 1985 Johnson 30HP Carb Rebuild
Yep, starter, all the hoses(mark where they go an take a picture) probably the choke solenoid. and wire. You have to be able to get to the two nuts attaching the carb to the intake and then be able to pull it straight out.Unclip the advance wire on the top too.
wilde1j
You got ~ a gallon of carb cleaner you soak the carb in, right? The spray stuff is useless, you need to soak the carb, the blow dry with compressed air to clean it properly.
nguoi_viet41
CHEM-DIP? PARTS CLEANERS
The fastest acting immersion cleaner for all metal parts including alloys. Non-corrosive to metal and requires no agitation. A chemical seal retards evaporation and aids in emulsification. Removes carbon, varnish, paint, sludge, and grease fast. Use for cleaning transmissions, carburetors, valves, and other
hard to clean parts.
Sizes Available:
Part #0901 NET 1 Gallon Can (Replenisher)
Part #0905 NET 5 Gallon Pail PROFESSIONAL
Part #0996 NET 96 fl. oz. w/basket
Other Components Available:
Part #0950 Basket for #0905
carb cleaning instructions
